May 19th, 2024, 6:50am
"low-interference" DCDC-converter (Read 1584 times)
Berti
Apr 10th, 2008, 5:29am
I am working on a DCDC-converter for a SOC. It is important that the converter generates
low interference (e.g. switching noise). But most of the publications about DCDC-converter focus on
efficiency (which is secondary in my case, but a LDO is still not good enough).
Can somebody give me suggestions (literature) about "low-interference" DCDC-converters (e.g. using dithering etc.)?
Re: "low-interference" DCDC-converter
Reply #1 - Apr 11th, 2008, 4:43pm
Berti,
  Some designers, at least at the university level, are starting to use Sigma-Delta
controllers for DC-to-DC Converters to reduce noise and improve performance. Still
seems a little experimental but it is an interesting approach.
http://users.ece.gatech.edu/rincon-mora/publicat/journals/iecon05_tran_bypss_bst...
Reply #2 - Apr 15th, 2008, 12:39pm
You might want to post some more specifics about what you want to do. Any switching converter is going to be noisier than a linear regulaotr (classic, LDO or whatever) but need to know more about your system architecture requirements.
Berti
Reply #3 - Apr 15th, 2008, 10:44pm
Thank you Sheldon for the reference. I found some interesting literature.
Loose-electron,
The dcdc-converter is for a wireless transceiver. As the circuits operate from a lower supply than the battery voltage, a dcdc-conveter is mandatory for low power consumption (and
the efficiency of a LDO is unfortunatly not acceptable).
First measurements have already been quite good. But the trasmitter is very sensitive and the interference from the dcdc-converter should be reduced further by 20dB.
I think it is difficult to give absolute specs for isolation since the some of the coupling paths have been identified, but they are difficult to model.
So I was wondering what other techniques I can incoorporate into the existing dcdc-converter (PWM buck converter) to further reduce the switching noise.
Cheers
Reply #4 - Apr 16th, 2008, 6:26am
Berti,
  This is probably not the direction you are looking for and is more of a philosophical
question. However, it if the design is so sensitive to noise, does integration make
sense? I don't understand the economics driving your project, but would System
in Package, SiP, be a better approach than integration for this level of performance?
SiP would give you an opportunity to use passives to reduce noise, etc. that is
difficult to do in integrated designs.
Berti
Reply #5 - Apr 16th, 2008, 10:30pm
Sheldon,
SiP and solutions with external power switches have also been considered.
But BOM and customer demands don't allow that.
Reply #6 - Apr 25th, 2008, 6:38pm
Berti,
  My office is moving and while cleaning up my desk found another paper
that may be useful.
   "All-Digital DPWM/DPFM Controller for Low-Power DC-DC Converters"
    by Wang, Rahman, Lukic, Prodic
It describes an all-digital dc-to-dc converter. Since the dc-to-dc converter
operates at >6MHz. Operating at that frequency should keep the ripple at
the output down and out of the audio band. There is also a pretty extensive
bibliography you can use to study the prior art.
