Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Aug 17
th
, 2024, 12:33am
Home
Help
Search
Login
Register
PM to admin
Design
Analog Design
› Temperature compensation
Previous topic
Next topic
Temperature compensation (Read 2134 times)
Ghitani
Apr 17
th
, 2008, 5:49pm
Hi everybody,
Can anyone suggest me ideas for temperature compensation in ring ICO i.e. making tuning C/Cs less
sensetive to temperature variations?
Ghitani
IP Logged
Berti
Re: Temperature compensation
Reply #1 -
Apr 17
th
, 2008, 11:42pm
Should your ring-ICO need a bias current you could use a PTAT current.
I some cases this helps to reduce the temperature variations (depending on
the implementation of the ICO).
Cheers
IP Logged
Ghitani
Reply #2 -
Apr 18
th
, 2008, 4:05am
Thanks for your reply.
Regarding architecture, I used replica bias ICO with a differential delay cell of triode load (similar to Razavi's).
Is the PTAT current is the only solution?
Ghitani
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
»» Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
