Jul 19th, 2024, 10:21pm
how to make the ring vco start? (Read 3101 times)
neil
Apr 20th, 2008, 8:59am
hi,everyone,
  i am design a 3-order ring vco with the CSL(CSA) delay cell( single input),
it doesn't start up.and i don't know what level  the CSL input should be biased to get the gain A0>=2.
it looks like A0>=2 can't be obtained. i guess the input MOS is in linear region,and it 's gain is very small.
...i use the .ic inatiation ,and the vco can start.but it can start without giving a  inatiation.
..i don't know why...anyone can help me?   thanks.
Stefan
Re: how to make the ring vco start?
Reply #1 - Apr 20th, 2008, 9:05am
Maybe it's not the A0, but missing transient noise sources or even better missing initial conditions that will make the whole chain even _start_ oscillating. An insufficient A0 should show a damped oscillation that would finish soon, is that what you're seeing at your output ?
View Profile 16731287   IP Logged
Berti
Reply #2 - Apr 22nd, 2008, 12:11am
Neil,
I agree with Stefan. The simulator will even find a stable operating point for a ring-oscillator constisting
of CMOS inverters. However, in reality, this operating point won't be stable because of noise sources, and it will
start to oscillate. Only initial condition can help to happen this in simulation. Nevertheless, you should take a
carefull look at your circuit to make sure that this is really the case.
Reply #3 - May 14th, 2008, 3:35pm
Agree with the rest, the op point will get found where everything sits at half scale, because your models are ideal and matched, with no offsets or noise. Generally, an IC on one node of the ring oscillator (tug something off the center line) will get the thing to perform as expected.
