Aug 16th, 2024, 2:41pm
A design problem (Read 1170 times)
AnalogDE
A design problem
Apr 21st, 2008, 5:07pm
Let's say I have a voltage generator that generates a voltage called V1.  I want to produce an output, Vout where Vout = V1 + V2.
I want V2 to be some sort of voltage DAC, that is process and temperature independent.  Could you please give some circuit solutions, and the pros/cons of each?
Thanks!
