AnalogDE
Let's say I have a voltage generator that generates a voltage called V1. I want to produce an output, Vout where Vout = V1 + V2.
I want V2 to be some sort of voltage DAC, that is process and temperature independent. Could you please give some circuit solutions, and the pros/cons of each?
Thanks!
