didac
![* *](https://designers-guide.org/forum/Templates/Forum/default/stargold.gif) ![* *](https://designers-guide.org/forum/Templates/Forum/default/stargold.gif) ![* *](https://designers-guide.org/forum/Templates/Forum/default/stargold.gif)
![](https://designers-guide.org/forum/avatars/blank.gif)
There's a million ways to see the things in life
manresa,spain
Hi, A capacitance loading this kind of dividers could be a real problem, you must codesign a buffer to isolate the divider from the load(with a small transistor as the input of this buffer to avoid this loading). Also in the layout you must pay attention to the parasitics of the output lines(believe me I expended 4 hours optimizing the outputs of one of this dividers at layout level). About that a tiny input makes the divider work it's not strange at all, I recommend that you do a 2-D parametric with the input signal(Vin and fin), if you plot like a contour with Matlab you will see the two operating regions(free running and locked divider) and you will also see how depending on the input frequency more or less input level is needed for the divider to work(you can also see if your frequency it's too close to the limit where the divider will stop working). Hope it helps, PS:it's compulsory the use of a master-slave divider?,maybe it's worth the effort to see at an Injection Locking frequency divider(the problem it's the area overhead...)
