The below is the an example.
Open icfb, Click Import -> CDL… in CIW. Fill in CDL netlist File: Output Library: Top Cell: Reference Library List: Device-Map File: The Reference Library contains tsmc18rf and analogLib, where tsmc18rf is the PDK library provided by TSMC. The analogLib is put in the reference library list because a resistor symbol is required while the symbol in tsmc18rf does not generate the dimension and value correctly. The Device-Map File is titled map.in here and shown below. devMap := nfet nmos3v propMatch :=subtype ND devMap := nfet nmos2v propMatch := sybType N devMap := pfet pmos3v propMatch := subType PD devMap := pfet pmos2v propMatch := subType P devMap := diode dioden3v propMatch := subType DB devMap := resistor res propMatch := subType rp devMap := resistor rnplus propMatch := subType rnodrpo_m
Edit the netlist, append the following in each card for resistor. $[rp] W=1U L=1U M=1 Add the following lines if there are resistor, capacitor, diode, or triode. PARAM *.BIPOLAR *.RESVAL *.CAPVAL *.DIOAREA *.SCALE METER
Comment the line below, .GLOBAL VSSPST VDD VSS VD33 POC otherwise pins VSSPST VDD VSS are not generated in the schematic. I don’t know the reason why it does not inhibit VD33 and POC in the generated schematic. BTW, Global Node Expansion is chosen as Full in Virtuoso® CDL In window. What does it mean?
Good luck! Yawei
