aaron_do wrote on May 6th, 2008, 1:26am:So my question is, what comes out at the other end?
If you observe only Isig or Qsig, this signal has both negative and positive frequency components.
If Isig+j*Qsig has only positive frequency spectrum, Qsig will be Hilbert transformation of Isig.
aaron_do wrote on May 6th, 2008, 1:26am:As a sub-question, is it possible to realize a signal with only a positive or only a negative frequency?
Yes, it is possible as far as you treat signal as complex signal Isig+j*Qsig.
