Aug 15th, 2024, 10:33pm
complex filter (Read 1686 times)
aaron_do
complex filter
May 06th, 2008, 1:26am
second question of the day is about the complex filter. From my understanding, all real signals (sine, cosine...) can be split into positive and negative frequencies. A complex filter uses the combination of I and Q signals to reject the positive or negative half of the spectrum.
So my question is, what comes out at the other end? If the output has no negative half, then it must be a complex signal. So what would we see on the oscilloscope?
As a sub-question, is it possible to realize a signal with only a positive or only a negative frequency?
thanks,
Aaron
Re: complex filter
Reply #1 - May 6th, 2008, 1:51am
aaron_do wrote on May 6th, 2008, 1:26am:
If you observe only Isig or Qsig, this signal has both negative and positive frequency components.
If Isig+j*Qsig has only positive frequency spectrum, Qsig will be Hilbert transformation of Isig.
Yes, it is possible as far as you treat signal as complex signal Isig+j*Qsig.
