Jul 16th, 2024, 10:31pm
VCO CELL (Read 4061 times)
jamie
China
VCO CELL
May 12th, 2008, 6:19pm
Is anyone can tell me the advantages of the capaciter connecting like this in the VCO cell? Embarrassed
Re: VCO CELL
Reply #1 - May 14th, 2008, 3:48pm
It is in there to make the switching delay in the cell last longer and make the VCO tun at a lower  frequency.
jamie
China
Re: VCO CELL
Reply #2 - May 14th, 2008, 5:35pm
I want to konw why it cennects between the  differential output?
Berti
Re: VCO CELL
Reply #3 - May 15th, 2008, 12:07am
Smaller capacitor area, less coupling from ground into the output nodes .... ?
Re: VCO CELL
Reply #4 - May 15th, 2008, 11:27am
Berti wrote on May 15th, 2008, 12:07am:
Berti is correct -  Look at the equivlanet small signal circuit that is ground connected, it would be 2 capacitors from the two signal nodes to ground. Take the differential approach and the capacitor gets connected accross the signal nodes instead, and the total capacitance gets divided by two in value (insted of C1, C2 each being 1pf, the Cacross would be 0.5pf)
Add to that a differential system with no capactive load to ground noise.
Whenver possible, you want to keep systems differential.
-- Jerry
jamie
China
Re: VCO CELL
Reply #5 - May 15th, 2008, 4:46pm
Thank you very much. Smiley
