Berti wrote on May 15th, 2008, 12:07am:Smaller capacitor area, less coupling from ground into the output nodes .... ?
Berti is correct - Look at the equivlanet small signal circuit that is ground connected, it would be 2 capacitors from the two signal nodes to ground. Take the differential approach and the capacitor gets connected accross the signal nodes instead, and the total capacitance gets divided by two in value (insted of C1, C2 each being 1pf, the Cacross would be 0.5pf)
Add to that a differential system with no capactive load to ground noise.
Whenver possible, you want to keep systems differential.
-- Jerry
