I can't find any design issue in your post.
Your question is not design issue but simple usage of EDA tool.
Please post to "The Designer's Guide Community Forum ≫ Simulators ≫ RF Simulators".sandman wrote on May 14th, 2008, 3:16am:This is probably a question for a HP/Agilent ADS user forum, but I couldn't get help for it anywhere else.
I can not find your post in "Agilent EEsof Forums". Did you post to "Agilent EEsof Forums" ?
If you post there, I can answer there.
Agilent Home >Products & Services > Test & Measurement >
Agilent EEsof EDA > EEsof Knowledge Center > Discussion Forums
Agilent EEsof Forums > ADS > Analog Simulationhttps://edasupportweb.soco.agilent.com/cgi-bin/yabb/YaBB.plsandman wrote on May 14th, 2008, 3:16am:In a phase noise simulation, I'm looking to add phase noise to a VCO (V_1Tone source) by means of a phase noise table (Frequency->Corresponding Phasenoise@Frequency). This is usually done using the DataAccessComponent, but I've not been able to get it to work.
Why do you use "DataAccessComponent" ?
Do you understand use model of "DataAccessComponent" ?
You can set phase noise data using list() function very simply.
See manual of ADS.
http://eesof.tm.agilent.com/docs/adsdoc2005A/ccsrc/index.htmlYou want to set phase noise via external file instead of directly setting ?
It might be possible, if you invoke makearray() and access_data() functions.
If you need more informations, post to "Agilent EEsof EDA > EEsof Knowledge Center > Discussion Forums".
There you can get many answers from Agilent's guys and ADS's expert users.
If no one answered, I will answer you there.
