Jul 16th, 2024, 11:36pm
different NF results from "sp" and "noise" analysi (Read 2605 times)
rf_man
May 15th, 2008, 1:08am
different NF results obtained from "sp" and "noise" analysis of Spectre, the circuit is a LNA, the difference is about 0.2dB.
setup as follows:
sp: do noise= yes, mode= single ended
noise: output noise = voltage
         input noise = port
which one is more accurate? why the results are different?
didac
There's a million
ways to see the
things in life
manresa,spain
Re: different NF results from "sp" and "noise" ana
Reply #1 - May 15th, 2008, 2:10am
Try to select in noise output noise:probe. If you don't select this option spectre takes into account the noise from the load and the results from sp and noise differs.
Hope it helps,
Reply #2 - May 15th, 2008, 2:11am
rf_man wrote on May 15th, 2008, 1:08am:
setup as follows:
         input noise = port
In your setup, result of "sp" is correct as NF.
Why don't you specify "port" as "output noise" in "noise" analysis setup ?
Or if you set output port temperature as 0 Kelvin, you can get same NF from "noise-ana" as "sp-ana" even though you specify "voltage" as "output noise" in "noise" analysis setup.
