rf_man wrote on May 15th, 2008, 1:08am:different NF results obtained from "sp" and "noise" analysis of Spectre, the circuit is a LNA, the difference is about 0.2dB.
setup as follows:
sp: do noise= yes, mode= single ended
noise: output noise = voltage
input noise = port
which one is more accurate? why the results are different?
In your setup, result of "sp" is correct as NF.Why don't you specify "port" as "output noise" in "noise" analysis setup ?
Or if you set output port temperature as 0 Kelvin, you can get same NF from "noise-ana" as "sp-ana" even though you specify "voltage" as "output noise" in "noise" analysis setup.
