May 17th, 2024, 12:32pm
Flicker Noise Under Switched Biasing (Read 525 times)
aaron_do
May 17th, 2008, 1:21am
just wondering if anyone is familiar with flicker noise reduction using switched biasing. I have two questions...
1) Does the flicker noise reduction only occur for OFF/SAT or will it also occur for LIN/SAT assuming both result in IDS=0 during the OFF or LIN state?
2) It seems to only occur at quite low frequencies (1 kHz) compared to a normal flicker noise corner (1 MHz). Is that right?
thanks for any input,
Aaron
Re: Flicker Noise Under Switched Biasing
Reply #1 - May 19th, 2008, 6:12am
1) You'll get some reduction due to the duty cycle, of course.  But I think the main reduction won't be seen for LIN/SAT, because the channel still exists, and the trapped carriers aren't freed.  When doing OFF/SAT, the channel disappears in OFF and the carriers are much more likely to come out of the traps than go in, so when the next SAT portion occurs, there are far fewer trapped carriers to be causing the flicker noise.
