Aug 15th, 2024, 1:24am
problems for a mos transistor modeled in vhdl-ams (Read 3337 times)
alinalin19832007
roman
May 24th, 2008, 2:48pm
Im trying to simulate an transistor that is modeled in vhdl-ams in Cadence environment IUS 5.7. The problems is that this model works fine IUS5.5 but in IUS5.7 i have some oscilations in the moment I try to switch off.
Can explain anybody why is this thing ?
What are the difference between two IUS?
thank y very much
I hope u understand what i want to say?  ;)
Re: problems for a mos transistor modeled in vhdl-
Reply #1 - May 27th, 2008, 5:27am
Could be you're just getting lucky with one IUS.  What does the capacitance model look like?  Is it (correctly) formulated in terms of charge instead of capacitance * voltage?  What happens to the channel charge when the device is suddenly turned off?
alinalin19832007
roman
Reply #2 - May 29th, 2008, 1:09pm
The model works fine vgs<vds+3V , i dont know why is that
