Jul 18th, 2024, 12:28am
Question about OTA-C filter ^^ (Read 5307 times)
yixiusky
May 26th, 2008, 6:36am
Hello everyone, i have some questions about OTA-C filter design, I would like to share with all of u, thank u very much ! ^^
Design object :        tunable bandpass filter
Tuning frequency range :    50M-860MHz
Bandwidth of filter :   15MHz
a . Consider all of requirements, i decide to use OTA-C filter.   However I don't know is there other choice exept gm-c filter? How about your opinion? ^^
b. about the requirement of OTA design
1) the phase marge of OTA shoulbe 90 degree
2) How to decide the bandwidth and gain of OTA ? I have no idea
3) The linearity of OTA also should be improved. By using source degeneration... I still can not get good linearity
4) Do you think it is possible design one filter with this range tuning ability?
Sorry to ask so many questions Sad
thank you very much ^^
View Profile yixiusky   IP Logged
buddypoor
Bremen, Germany
Re: Question about OTA-C filter ^^
Reply #1 - May 27th, 2008, 1:13am
Hi Yixiusky,
Iīll try to give some answers:
In general, OTA-C structures are appropriate for tunable filters,however, an upper limit of about 900 MHz seems to be problematic. Monolithic integration iis necessary.
No problem as the OTA normally has no feedback.
OTA has no "gain", but a transconductance instead. Frequency range could be a problem.
What means "good" ? What are your requirements regarding dynamic range and input/output levels ?
No, I donīt think so. More than that, a tunable BP structure with a constant bandwidth (instead of constant Q) is hard to design. So, it looks not too good for your task.
yixiusky
Reply #2 - May 27th, 2008, 4:37am
buddypoor^^ Thank you very much.
I would like to discuss with u more, since i am not totally get your idea Sad
a . In general, OTA-C structures are appropriate for tunable filters,however, an upper limit of about 900 MHz seems to be problematic. Monolithic integration is necessary.
Question : I am not clear about "Monolithic integration is necessary". I read some papers, people can design the filter up to GHz with gm-c filter. i would like to know your meaning, thank you!
Question: OTA has Iout/Vin (transconductance).  But when we design OTA for OTA-C filter, how can we set the specification for OTA? And what's the relationship of OTA's bandwidth and bandpass filter's bandwidth?
Question: "Good" means i would like to get IIP3=15dBm for OTA-C filte. But now i only get -9dBm.  so i modify the OTA, add source degeneration. but still can not get 15dBm IIP3 Sad
Question: I would like to know what's the reason you feel one filter is impossible to cover whole frequency range? based on analysis or ..
5) I would like to build the 4th order biquad OTA-C filter, but i don't know the exact steps to build OTA-C filter. It is not like
active-RC, we can use "filter solution" to get coefficient...I am really confuse and not clear Sad
sorry to ask so many questions Smiley
sincerely yours
yixiusky
buddypoor
Bremen, Germany
Reply #3 - May 28th, 2008, 1:02am
Hi, Yixiusky,
Iīll try to clarify something.
It is not recommended to design a filter near 1 GHz from lumped elements. Therefore, monolithic integration (IC) is necessary. Is this a problem ?
Are you sure that bandwidth has to be constant for different mid frequenncies ? This means the filter Q will rise up to 57 ! More than that, a filter structure wich can be tuned with constant bandwidth is hard to find.
I donīt understand - does this mean you have already chosen an OTA type ? Or do you design an OTA by yourself ?
I understand that your filter has to be TUNABLE . Is this correct ? Or are you to design several filters with different frequencies within the band you have mentioned ? As already said, tuning with constant BW (and rising Q) is a big big problem within this band.
I would like to build the 4th order biquad OTA-C filter, but i don't know the exact steps to build OTA-C filter. It is not like active-RC, we can use "filter solution" to get coefficient...I am really confuse and not clear Sad
Why 4th order ? Why biquad type ? Another problem: 4 th order and tunable ??? (nearly impossible).
Recommendation: You should check all requirements again and sort them in a systematic manner with the aim to select one concept (filter structure and realization). At the moment your information about requirements are confusing and partly contradictory: biquad type bandpass of 4th order, mid frequency tunable with constant BW between 60 MHz  and nearly 900 MHz.
good luck
yixiusky
Reply #4 - Jun 1st, 2008, 5:54am
Thank you very much, buddy  :)
I will follow your recommendation and make my requirements in a systematic manner:
4th order biquad type gm-c bandpass filter, mid frequency tunable with constant BW between 60 MHz  and 860MHz.
As u said ""I donīt understand - does this mean you have already chosen an OTA type ? Or do you design an OTA by yourself ?Why 4th order ? Why biquad type ? Another problem: 4 th order and tunable ??? (nearly impossible).   "
Answer : (1) yes, i am designing ota-c filter now, and design OTA by myself.  But i am not sure the phase margin of OTA
                    must be 90 degree or not.
               (2) I design 4th order, because i need 3rd order harmonic rejection ration larger than 30dB.  With 4th order i
                     can  get this 30dB rejection ^^
Thank u very much ^^
buddypoor
Bremen, Germany
Reply #5 - Jun 1st, 2008, 6:41am
Donīt care about phase margin or other details which are not important during the first design phase.
The main question is: Did you find any 4th order filter topology which is tunable and has constant BW  ?
I would be surprised !
yixiusky
Reply #6 - Jun 1st, 2008, 6:21pm
Smiley  Tunable bandpass filter with constant BW is my design goal.
So i should try to achieve this goal. The normal biquad can not satisry this goal so i should add bandwidth tuning circuit to the filter also ^^   i will try to make it ^^  thank you very much for your instruction ^^
