Jul 16th, 2024, 11:13pm
Floquet eigenspace error during pnoise sims (Read 3671 times)
aval
May 26th, 2008, 9:29am
I am running pss+pnoise analysis on LDO + VCO (LDO being the power supply for the VCO). The VCO is a ring oscillator. All bondwire models are included and so are external capacitances on the LDO.
I get the following warning from pnoise:
"The Floquet eigenspace computed by spectre PSS analysis appears to be ill-defined. PNOISE computations may be inaccurate. Consider re-running the simulation with smaller reltol, different tstab(s), and method=gear2only. Check the circuit for unusual components."
I have tried out the suggestions (smaller reltol, increased tstab, gear2only). The warning does not go away. The warning does go away if the bondwire inductances are taken out. I would however like to simulate the noise with the bondwire inductances.
Any ideas on what could be going wrong here?
thanks in advance,
Aarathy
didac
There's a million
ways to see the
things in life
manresa,spain
Re: Floquet eigenspace error during pnoise sims
Reply #1 - May 26th, 2008, 9:55am
Time ago I find a similar problem with pss(I don't remember the error message), in my case was caused by bondwires without real part, adding a small amount of series resistance helped to solve this issue.
Hope it helps,
aval
Reply #2 - May 27th, 2008, 12:46am
Thanks! That did work!!
I had missed the series resistance for ground and substrate connections. Once I included those, the problem went away.
thanks once again!
Aarathy
« Last Edit: May 27th, 2008, 4:30am by aval »
