Aug 17th, 2024, 3:19am
High speed, high mirror ratio current mirror (Read 3689 times)
AnalogDE
May 27th, 2008, 2:24pm
I am trying to design a current mirror with a high mirroring ratio (1:12, input current=40uA, output=480uA).  Do you think the topology attached could work?  How should I size the source follower and current source?  I need very fast settling time, ~10ns.
weber8722
Re: High speed, high mirror ratio current mirror
Reply #1 - Mar 17th, 2009, 7:27am
for good settling you need a frequency compensation. Use a series RC from input to Vdd, like 500fF + 10k.
Otherwise you get a large overshoot and big noise peaking too.
Bye Stephan
rf-design
Reiner Franke
Reply #2 - Mar 24th, 2009, 10:39am
Very fast depending on your tech, Vdsat and Length.
A good guess is to have a sqrt(12) * input current on the mirror buffer.
vivkr
Reply #3 - Mar 25th, 2009, 12:04am
AnalogDE wrote on May 27th, 2008, 2:24pm:
I would also try to see if a Wilson current mirror could be used (headroom permitting). This is generally quite fast for high mirror ratios.
Vivek
