Jul 17th, 2024, 1:23am
Jitter relation between VCO & loop divider output (Read 874 times)
keikei
beijing
May 28th, 2008, 7:01am
In a PLL locked to a reference frequency,  what is the relation between the jitter of VCO output ('Jvco') and the jitter of the signal fedback to PFD input after the loop divider ('Jdiv') ? assuming the div ratio is N.
In a certatin paper the author gives Jvco = N * Jdiv. But according to some early discussion here, most people agree that Jvco = Jdiv. So I am totally confused.
Is the effect of divider on jitter dependent on its location, i.e., in loop or out of loop?
Stefan
Re: Jitter relation between VCO & loop divider out
Reply #1 - May 28th, 2008, 7:08am
It's just some basic stochastic equation
the standard deviation of N statistical indepedent events, each having a standard deviation of J1 is
JN=sqrt(N)*J1.
So neither one of the formulas you spoke about is correct.
And please don't talk about "certain papers", quoting them is more efficient here Smiley
View Profile 16731287   IP Logged
keikei
beijing
Reply #2 - May 28th, 2008, 8:39am
yeah, I should have specified the paper name:
Time-to-voltage converter for on-chip jitter measurement, IEEE TRANSACTIONS ON INSTRUMENTATION AND MEASUREMENT, VOL. 52, NO. 6, DECEMBER 2003 by Tian Xia and Jien-Chung Lo
Visjnoe
Reply #3 - Jun 6th, 2008, 11:19am
Dear,
Jvco = Jdiv (for jitter components within the PLL bandwidth).
The formula with the sqrt(N) relationship does not hold. It only applies for calculating the jitter of a divider chain constituted out of N unit elements (e.g. div 2). When the jitter of a unit element Junit is known, the total jitter of the chain (divider) is given by sqrt(N)xJunit.
The phase noise before and after the divider has a 1/N^2 relationship. Since the period becomes N times longer after the division,
the jitter is the same.
Peter
