Jul 18th, 2024, 12:39am
How many parameters of PLL system can be simulated (Read 6580 times)
icsoul
May 29th, 2008, 5:21am
How many parameters of PLL system can be simulated on earth?
In behavior and transister level.
1. the lock range
2. the lock time
3. the pull in range
4. the pull in range
5. the pull out range
6. the hold range
7. the loop bandwidth
8. the close loop bandwidth
9. the phase noise
10. the jitter
11. the nature frequency
12. the damping factor
13. the vco noise transfer curve of the whole pll system
14. the input noise transfer curve o the whole pll system
etc.
What I mean is to simulate the whole pll system to get the parameters, and is NOT to simulate the building blocks and calculate these parameters.
Maybe some parameters can be simulated, while the others cannot be. Give your opinions and methods.
Welcome to discuss~
buddypoor
Bremen, Germany
Re: How many parameters of PLL system can be simul
Reply #1 - May 29th, 2008, 1:29pm
Up to now, I succeeded in simulating 1-8, 11,12  and in addition: phase error, demodulation properties.
David Lee
Reply #2 - May 30th, 2008, 12:37am
buddypoor wrote on May 29th, 2008, 1:29pm:
I'm happy to say that with transient noise, all the remaining parameters on your list
 9 - PLL phase noise
10 - PLL jitter
13, 14 - PLL noise transfer
can be simulated at the transistor level.
- David
icsoul
Reply #3 - May 30th, 2008, 2:00am
Hi, David Lee and buddypoor
Could you please introduce the simulation method in detail?
Thanks~!
buddypoor
Bremen, Germany
Reply #4 - May 30th, 2008, 3:11am
I must confess, up to now I have simulated the mentioned PLL parametrs on block level only (using the software VISSIM, which - for my opinion - is very handsome and powerful)
Each simulation was based purely on the parameter definition. For example to measure pull-in time and pull-in range  I did nothing else than to apply two different frequnecies and watch the VCO control signal. As soon as it settles the pull-in process has ended. The same applies to all ac measurements, which are valid only in the locked state.
Therefore, I´ve used the linear model with phase as inputs.
A detailed description seems to be very large in space.
David Lee
Reply #5 - May 31st, 2008, 11:40pm
icsoul wrote on May 30th, 2008, 2:00am:
Thanks~!
I have simulated several frac-N and integer-N PLLs at the transistor level using Berkeley Design Automation's Analog FastSpice. Its transient noise analysis models transistor noise as current sources with random values based on the noise intensity information from the device model. By injecting this random noise for each device noise source at each timestep during transient simulation, it produces output waveforms that include realistic noise effects.
- David
icsoul
Reply #6 - Jun 3rd, 2008, 3:59am
David Lee wrote on May 31st, 2008, 11:40pm:
Thanks~!
David Lee
Could you introduce how to simulate the PLL loopbandwidth and noise character as a whole system?
joel
Reply #7 - Jun 17th, 2008, 5:01pm
For loop bandwidth, modulate your reference clock at some frequency, and measure the corresponding output frequency modulation.   Sweep the modulation frequency.  When the normalized output frequency modulation amplitude is down by 3dB relative to normalized input modulation amplitude, you've got your 3dB loop bandwidth.  Basically when you can see it start to attenuate, you're roughly at the loop bandwidth.
By the way, I've had good luck using Evercad Adit for PLLs because it has a retriggering measure statement. E.g. For each posedge, measure the time till the next.  Do any other circuit simulators have this?  I'm not aware if it in hspice or hsim, but they're constantly adding freatures.  Cheers!  /jd
icsoul
Reply #8 - Jun 19th, 2008, 2:47am
joel wrote on Jun 17th, 2008, 5:01pm:
Thanks, joel
I  have done the simulation like your method a few days ago. But it is very slow.  Do you have any better method?
What't your mean about retriggering measure statement?  Do you mean that it can measure at every edge with one measure command?
It seems has no this feature in HSPIECE as I know.
joel
Reply #9 - Jun 19th, 2008, 11:27pm
Yes, that's what the function does.  I find it very useful.  Otherwise I have to generate a bunch of measures with a perl script, but having a thousand measures is slow to process.
>slow... Do you have a better method?
I think a high speed/capacity circuit-simulator like adit or hsim can run out 20uS of PLL simulation in an hour or two.  You just have to initialize the VCO control voltage to something reasonable.  This is the transient simulation 'real-world' approach.
Otherwise, you can solve it analytically with matlab or pencil & paper.  The loop bandwidth is supposed to be around 4 times the unity-gain frequency, which is defined in the text books.  I haven't made an effort to correlate my transient simulation results with analytical results, but I hope someone out there has!
