May 2nd, 2024, 11:12am
2 MHz Instrumentation Amp (Read 5100 times)
aaron_do
May 30th, 2008, 1:58am
I need some kind of buffer with SMA inputs with an input capacitance of no more than 2 pF to work up to 10 MHz. Does such a buffer exist, or do i need to design on-chip buffers?
thanks,
Aaron
Re: 2 MHz Instrumentation Amp
Reply #1 - May 30th, 2008, 6:51am
aaron_do wrote on May 30th, 2008, 1:58am:
As far as you connect an amplifier to DUT via 50ohm coaxial cable, a capacitance loaded to DUT is far larger than 2pF even though an input capacitance of amplifier is 2pF.
Or you expect 50ohm impedance of amplifier ?
What signal do you want to observe ? Oscilloscope ? Spectrum Analyzer ?
I use active high impedance probe both for Oscilloscope and Spectrum Analyzer.
There are many excellent probes available.
Or I use OP Amp of ADI. Then connect DUT to OP Amp with very short line on board.
I often use following.
http://www.analog.com/UploadedFiles/Data_Sheets/AD8138.pdf
Maybe AD8138 is too over spec for your purpose. You can find reasonable one in ADI's products.
But maybe on-chip buffer is most cheap.
« Last Edit: May 31st, 2008, 3:32am by pancho_hideboo »
aaron_do
Reply #2 - Jun 1st, 2008, 8:19pm
thanks for the reply. BTW, do you know what kind of input-referred noise I could expect from an active high impedance probe?
thanks,
Aaron
Reply #3 - Jun 1st, 2008, 10:04pm
aaron_do wrote on Jun 1st, 2008, 8:19pm:
You might be able to get such informations from data sheets of active probe.
By why don't you measure DUT ground with probe.
That is noise floor.
aaron_do
Reply #4 - Jun 1st, 2008, 11:15pm
Oh i don't actually have the probe at the moment. My university bought a very high-end (up to 20+ GHz) one from picoprobe but there were compatibility issues. So i was thinking of suggesting to my supervisor to try and get a lower-end active probe for use up to only a few hundred MHz.  If i have to design a buffer just because the active probe's noise floor is too high then i would be a little more reluctant...
I have a data sheet for the high end probe but it says nothing about noise...
thanks anyway,
Aaron
