Aug 15th, 2024, 12:13pm
ADS Questions - about NFmin for AT41486 transistor (Read 8290 times)
mrnobody
Jun 01st, 2008, 8:11pm
I was wondering if I can get some advice here..
I am trying to design an LNA using AT41486 in ADS.
According to AT41486's datasheet, the NFo at 2GHz is 1.7dB at 2GHz, VCE = 8V and IC = 10mA.
However, in my ADS simulation (which the transistor is biased to Vce of 8V and IC of 10mA), the NFmin is around 23.
Attached is both the S param layout and the result.
I am not sure what I have done wrong..
Please advice.. thanks..
Re: ADS Questions - about NFmin for AT41486 transi
Reply #1 - Jun 1st, 2008, 9:29pm
I can't find any design issue in your post.
Your question is not design issue but simple usage of EDA tool.
Please post to
"The Designer's Guide Community Forum ≫ Simulators ≫ RF Simulators".
Or
Agilent Home >Products & Services > Test & Measurement >
Agilent EEsof EDA > EEsof Knowledge Center > Discussion Forums
Agilent EEsof Forums > ADS > Analog Simulation
https://edasupportweb.soco.agilent.com/cgi-bin/yabb/YaBB.pl
This is packaged BJT model.
AT41486 have 4 pins(c, b, e, e).
You open one emitter pin.
Try connect two emitter pins.
And why don't you set C1 as 10pF//100pF.
I've found your mistake.
You've set wrong port number.
You shouls set num=1 for input port.
And set num=2 for output port.
« Last Edit: Jun 2nd, 2008, 7:12pm by pancho_hideboo »
mrnobody
Reply #2 - Jun 3rd, 2008, 5:35pm
Thanks for the reply..
The NFmin obtained is 2.706dB, shouldn't it be 1.7dB (NFopt in datasheet)? I mean, shouldn't the NFmin's value be equal to NFopt value shown in datasheet..?
If I understand correctly, MFmin is the minimum Noise Figure of that transistor at VCE = 8V, IC = 10mA and Freq = 2GHz. Is it possible to make the NFmin lower, maybe around 1.7dB..? Please advice. I am very new in ADS thanks..
Re:
Reply #3 - Jun 21st, 2008, 10:00am
You are using old version of AT41486("pb_hp_AT41486_19920721"). Maybe this old version is not proper since it gives 2.55dB as NFmin even though I invoke ideal measurement condition.
I don't know why Agilent keeps to bandle this old version. You should contact with Agilent EDA support.
As GummelPoon Model, there are following three versions.
 #uselib "RfTransistorLibrary" , "pb_hp_AT41486_19920721"
 #uselib "RfTransistorLibrary" , "pb_hp_AT41486_19921101"
 #uselib "RfTransistorLibrary" , "pb_hp_AT41486_19931202"
As S-parameter models, there are following two models.
 "sp_hp_AT-41486_1_19920721"
 "sp_hp_AT-41486_1_19921201"
If you use S-parameter models, you get completely 1.7dB as NFmin.
And if you use "pb_hp_AT41486_19921101" or "pb_hp_AT41486_19931202", you get almost 1.7dB as NFmin.
