Aug 16th, 2024, 2:44pm
noise simulation of a pulse swallow divder (Read 3553 times)
claudette
Jun 09th, 2008, 7:40am
I m trying to find out the noise contribution of the pulse swallow diver in a pll. As the division ratio is very high (10000), it is very difficult to simulate the noise using pss+pnoise. Is there a way to simulate the noise efficiently?
thanks
claudette
Frank Wiedmann
Munich, Germany
Re: noise simulation of a pulse swallow divder
Reply #1 - Jun 9th, 2008, 11:33pm
Can you reduce the division ratio without changing the signal path? I would assume that this would not change the timing jitter produced by the divider.
claudette
Reply #2 - Jun 11th, 2008, 1:21am
Hi Frank, thanks for the reply.
If I reduece the division ratio,  I would also decrease the noise sampling frequency. After all I get different strobed phase noise. Can I mutlipy the noise by the factor I reduce the ratio, and say this is the phase noise I should get at a high division ratio?
Frank Wiedmann
Munich, Germany
Reply #3 - Jun 11th, 2008, 2:04am
If the timing jitter produced by your divider does not depend on the division ratio (you should of course verify if this is true for your circuit), the phase noise at the output will decrease when the division ratio is increased (same timing jitter/increased period duration).
