Aug 15th, 2024, 9:39pm
How to calculate the freq of the signal with vams? (Read 3055 times)
icsoul
Jun 10th, 2008, 4:30am
Is there one command for this function directly?
If not, how to implement this function simply?
Thanks.
Stefan
Re: How to calculate the freq of the signal with v
Reply #1 - Jun 10th, 2008, 4:45am
Frequency is the inverse of the period.
A period is defined as the delay between two positive crossings of a signal through a specified threshold (usually in the middle of the sine-wave).
So - what's the question ?
btw. maybe you should check the sourcecode section of designersguide Smiley
View Profile 16731287   IP Logged
icsoul
Reply #2 - Jun 10th, 2008, 5:43am
Stefan wrote on Jun 10th, 2008, 4:45am:
Thank you, Stefan
I'm newbie to veriloga. I do calculate the period, but an error is always be reported Sad.  Maybe the description method is not ritht.
Reply #3 - Jun 13th, 2008, 6:58am
Hint hint!  There's a model for "Period measurement" -- click "Verilog-AMS in the upper right of these pages.
