Jul 17th, 2024, 10:30am
minimum NF of Low-IF receiver (Read 2913 times)
aaron_do
Jul 01st, 2008, 12:44am
if i use an image-reject architecture, in theory i can completely cancel the image noise that appears in-band due to noise folding in a mixer.
However, in some receivers i've seen, image rejection is done in the digital domain. Just intuitively, since the signal is already digitized, the bit errors due to the noise in the signal are already there, so in theory the image noise cannot be canceled using digital domain image rejection.
Is that right?
thanks,
Aaron
Re: minimum NF of Low-IF receiver
Reply #1 - Jul 1st, 2008, 1:39am
aaron_do wrote on Jul 1st, 2008, 12:44am:
No. you are misunderstanding. Even though you apply image rejection mixer such as combination of I/Q down mixer and complex BPF, holding noise from mixer itself can not be canceled.
I can't understand why bit errors already exists there.
If quantized noise is enough small, there is no degradation in baseband BER.
so in theory the image noise cannot be canceled using digital domain image rejection. Is that right?
No, it is not correct.
Assume  an architecture where I/Q-ADC after I/Q down mixer and digital complex BPF or complex Bandpass-Delta-Sigma-ADC. you can realize image rejection architecture.
aaron_do
Reply #2 - Jul 1st, 2008, 1:52am
Hi pancho_hideboo,
thanks for the reply. Actually I have no experience at all with ADC design so maybe that's where my misunderstanding is coming from.
Anyway what do you mean by holding noise? Is that the intrinsic noise of the mixer? So the noise at the image frequency which is present before the mixer can be cancelled by the image reject mixer right?
thanks,
Aaron
Reply #3 - Jul 1st, 2008, 1:55am
aaron_do wrote on Jul 1st, 2008, 1:52am:
Right.
Right.
