May 18th, 2024, 12:45am
Jitter and load capacitance (Read 3706 times)
Visjnoe
Jul 10th, 2008, 2:42am
Dear all,
I noticed a strange phenomenon during jitter simulation of driven circuits (in casu: logic gates). The simulator used was HSPICE RF.
The logic gates were driven by a 50% duty cycle square wave. The number of sidebands was set to 250 and the jitter integration bandwidth  to 5GHz.
During a first set of simulations, I used a load capacitance of 0.1pF. I thought this was a conservative setting which would result in worst-case jitter results.
However, now I noticed that when I decrease the load capacitance to e.g. 0.01pF the reported jitter increases.
To me this is counterintuitive, since from handcalculations I would expect the jitter to decrease with decreasing load capacitance for synchronous (added) jitter by logic gates (e.g. INV, AND...).
Has anyone observed this too? Any (possible) physical explanation?
Peter
Ryan Cheung
Re: Jitter and load capacitance
Reply #1 - Jul 13th, 2008, 7:49pm
I have found the same problem in eldoRF, but in spectreRF everthing seems reasonable. You could try the simulation in spectreRF.
trond
Glasgow, Scotland
Reply #2 - Aug 2nd, 2008, 11:07am
Visjnoe wrote on Jul 10th, 2008, 2:42am:
Could you please point out a reference or link where I might be able to gain more mathematical insight into the jitter-load capacitance relationship.
Visjnoe
Reply #3 - Aug 25th, 2008, 10:53am
Dear Trond,
please have a look at the paper by Abidi on jitter in ring oscillators. It contains several insightful derivations, including the jitter-load capacitance relationship. You can also derive the relationship yourself by reading the papers on jitter from this website.
Peter
