Aug 15th, 2024, 9:40am
Why filter in front of LNA should be terminated with 50Ohm ? (Read 2100 times)
Julian18
Jul 10th, 2008, 10:06am
Hi, there
    Anyone want to explain for me why we should terminate a filter with 50Ohms? what if we dont and what is the effect? where can I get this kind of information?
ACWWong
Oxford, UK
Re: Why filter in front of LNA should be terminated with 50Ohm ?
Reply #1 - Jul 11th, 2008, 6:22am
If you mean SAW filter, then the filter characteristic is only guaranteed for the passband if the VSWR in the passband is low, so it needs to be matched. The SAW filter data sheets usually specify the specification.
Generally, RF filters need to be terminated in the correct impedance for the characteristics to be defined/maintained
