ACWWong
If you mean SAW filter, then the filter characteristic is only guaranteed for the passband if the VSWR in the passband is low, so it needs to be matched. The SAW filter data sheets usually specify the specification. Generally, RF filters need to be terminated in the correct impedance for the characteristics to be defined/maintained
