May 18th, 2024, 6:09am
Why to match thr first stage to a specific impedance (50ohms)?? (Read 4715 times)
zhangjerome
Jul 11th, 2008, 6:42pm
what's the drawback if it's not matched to 50 ohms??
Re: Why to match thr first stage to a specific impedance (50ohms)??
Reply #1 - Jul 11th, 2008, 10:41pm
zhangjerome wrote on Jul 11th, 2008, 6:42pm:
Your description is not sufficient.
What do you mean by first stage ?
What component or signal is connected to first stage as input ?
If any component such as BPF or anttena is connected, what value of its output impedance ?
See my post in http://www.designers-guide.org/Forum/YaBB.pl?num=1195659245
zhangjerome
Reply #2 - Jul 12th, 2008, 5:11am
By first stage I mean a low noise amplifer in the RF receiver chain. What will happen if this low noise amplifier is not well matched to a 50 ohms impedance? I know there is going to be reflection. How does this relfection degrade the receiver performance??
Reply #3 - Jul 12th, 2008, 7:05am
zhangjerome wrote on Jul 12th, 2008, 5:11am:
Gain(S21) is reduced. Then total NF of RX system will be degraded.
Maybe you don't understand various gains such as transducer gain, power gain, voltage gain, available power gain, maximum available power gain.
Cadence's Tool player often encounter same confusion.
http://www.designers-guide.org/Forum/YaBB.pl?num=1202753208/13#13
zhangjerome
Reply #4 - Jul 12th, 2008, 10:18pm
Thank you, Pancho.
You are right. I just confused by those gain definitions and the gain given by Spectre.
