Oct 4th, 2026, 4:49am
question about voltage regulator (Read 3074 times)
htshang
Jul 12th, 2008, 11:31pm
I met a problem about the voltage regulator. For a plane voltage regulator, we usually use an op-amp and a pmos (output stage) configuration to make negative feedback loop to get the regulated voltage. But why the regulator can regulate  voltage only on the condition that the voltage difference between the source and the drain of the output pmos was smaller than the threshold of the output transistor?
   In the simulation I used a pwl soure to model the source of pmos. I found  that the regulator lost its function when the source volatage exceed some value .
   I expect your help, thank you very much!!
View Profile 32623101   IP Logged
Berti
Re: question about voltage regulator
Reply #1 - Jul 13th, 2008, 9:33pm
I think that a LDO will also work with vds of the power transistor well above threshold.
I recommend you to check the loop stability since that will change over different regions
of operation (load current, input voltage etc.)
buddypoor
Bremen, Germany
Reply #2 - Jul 13th, 2008, 11:09pm
htshang wrote on Jul 12th, 2008, 11:31pm:
........I found  that the regulator lost its function when the source volatage exceed some value .
It would be much easyier to answer if you could give some figures.
Do you mean that the LDO regulates only if - for example - Vds=2 volts at Vgs= 3volts ?
Reply #3 - Jul 15th, 2008, 4:34pm
What you are describing is an LDO structure (PMOS as the pass transistor)
LDO devices vary over 30db in forward path gain as the PMOS transistor goes from saturation to triode region (a function of Vds)
That 30db needs to be taken care of in your control system model
htshang
Reply #4 - Jul 16th, 2008, 5:09am
First of all, thank you very much for all of the you.
Matybe I forgot to point out that the amplifier in my regulator is a current mode one. I do the ac analysis in closed-loop configuration, finding out the phasemargin is good. But when the voltagte difference between source(connect to positive power vext!, I use pwl source to simulate the power-up,for example :VVEXT!  vext!  gnd!  pwl(0 1 3u 5)) and drain(regulator output node)is bigger than threhold voltage(absolute value),then regulator output will track the vext! not stay to vref(regulator input voltage) anymore.
    In my opinion, when the voltage difference is bigger than threshold voltage, the current mode amplifier can not work properly as usual. If the amplifier is a voltage amp, then the matter will disappear. Just as Berti said--a LDO will also work with vds of the power transistor well above threshold.
'     For 'LDO devices vary over 30db in forward path gain as the PMOS transistor goes from saturation to triode region (a function of Vds)@loose-electron' I did not understand.
buddypoor
Bremen, Germany
Reply #5 - Jul 16th, 2008, 8:57am
htshang wrote on Jul 16th, 2008, 5:09am:
Does this mean that your error amplifier has a current output which is connected to the gate of a MOSFET ??? Or did I misunderstand something ?
HdrChopper
Reply #6 - Jul 16th, 2008, 9:30am
What he meant is that since the supply line you are regulating with the LDO can vary over a large range, the operating conditions for the LDO pass transistor could change from triode to saturation mode (triode when the supply line is close to the regulated line voltage, saturation when such voltages difference is large).
Consequently, since the LDO pass transistor is within the loop and the gain associated to its stage is a function of the operating condition, the loop gain can change as much as 30dB and this should be considered when analyzing stability.
Tosei
Keep it simple
Berti
Reply #7 - Jul 16th, 2008, 10:25pm
I also don't understand
Do you use an OTA? Or are both input and output current-mode?
Cheers
Reply #8 - Jul 19th, 2008, 12:47pm
Tosei - Nicely stated - thanks for doing my follow up!  :) -- Jerry
HdrChopper wrote on Jul 16th, 2008, 9:30am:
Tosei
average
Reply #9 - Jul 27th, 2008, 7:27pm
 do you check the body diode of pmos, maybe there is an leackage current at it .
average
