HdrChopper
Hi Neoflash,
I guess there is some dependency on the type of process you´re using, but typically the max allowable and reliable junction temperature (infinite time) for silicon is 165C. Higher temperatures might be allowed but assuming shorter times as such temp is increased. So, 30C over 125C should not be a problem
Regards Tosei
