thank you very much ! I would like to discuss more ^^
I attach the filter and formular ^^
I am designing 2nd-order gm-c bandpass filter now. I want to design the center frequency of bandpass filter is 860MHz, and the bandwidth is 20MHz. According to the transfer function, center frequency, Q factor value, I have some questions:
(1) after calculation, i set the gm3,gm4,c1,c2 to get the center frequency 860MHz, but it is different from the theroy. Also. if we want to change the center frequency, which value should we change? Gm3,Gm4 or C1, C2. and when I change anyone, the phase of integrator will be change, not 90 degree anymore
(2) use B=Gm2/C1, i set the bandwidth of the filter. But it is also not exactly same. I guess because of parasitic capacitance, is that true?
(3) From the formular, after we choose the very high value Gm3. Gm4, and very small value Gm2, we can get very high frequency and very narrow bandwidth. But in practical, when I desing, it is not ture
Sorry to ask so many questions
I am designing a RF tracking filter now. So i need to tune the center frequency from 50MHz to 860MHz, and keep narrow bandwidth about 20MHz. when i tune the circuit, i can not make sure the specification.
Thank you very much ^^
have a nice day ^^
