May 16th, 2024, 11:35pm
Pnoise issues with transient noise (Read 4305 times)
Rwalker
Jul 18th, 2008, 7:23pm
Been working on a SC BPF for a while, simulating with spectreRF.  I use current mode integration sampling at the input to a SC biquad, and find that noise aliasing at the input is described by a transient noise derivation I came up with involving finite integration length.  When simulating with pnoise I see the expected noise in baseband (including the folding predicted by the transient derivation), but I also see up-conversion of strong low frequency noise to my clock freq and 10x clock freq.  I recognize that the spectrum of the noise currents should have up-conversion of the low-f noise (I essentially chop them with my sampling phase), yet I feel that the noise at the output of my filter due to these low-f components should all be at baseband, and I bang my head against the wall trying to find a physical explanation.
Could these be sim artifacts from trying to do a periodic noise simulation on a transient noise phenomenon?  Or maybe I should bang my head more?  Thanks!!
Re: Pnoise issues with transient noise
Reply #1 - Jul 18th, 2008, 8:12pm
Rwalker wrote on Jul 18th, 2008, 7:23pm:
What do you mean by "transient noise" also in "Pnoise issues with transient noise" ?
I can't know your situation.
Show me more detail simulation setup and result's graph.
Maybe, yes.
Rwalker
Reply #2 - Jul 21st, 2008, 2:06pm
Thanks for the reply.
Found my issue, I had a poorly chosen Pnoise frequency sweep and had points right on fclk and 10*fclk.  I seem to have minor up-conversion of low-f noise that was being greatly exaggerated.
Reply #3 - Jul 21st, 2008, 5:00pm
Rwalker wrote on Jul 21st, 2008, 2:06pm:
Maybe no one can understand your situation at all with your explanation.
What do you mean by "transient noise" in "a transient noise derivation" and "Pnoise issues with transient noise" ?
Do you mean "time domain noise" in Pnoise analysis or "monte calro type noise" in transient analysis ?
Rwalker
Reply #4 - Jul 21st, 2008, 5:07pm
pancho_hideboo:  I'm not trying to explain my situation anymore because it is solved.  Please see my post above. Thank you.
