Sep 17th, 2024, 8:13am
Poly Resistor Current density/Power density Guidelines (Read 1407 times)
eppramod
Jul 23rd, 2008, 5:05am
Experts,
Don't know if this topic was discussed here.
I would like to know while sizing Poly resistors (silicided/or unsalicided)
what should be the critical parameter W or L in terms of reliability?
To be more specific i read somewhere that resistor degradation mechanism in lower technologies is more due to Joule (self) heating
rather than Current induced EM (Jmax limits).
So people fix min W for Current density (Jmax) limits and people may have to think min L for Power density reasons.Even very low Jmax
values can raise the local temperature considerably?
Please give your thoughts
vivkr
Re: Poly Resistor Current density/Power density Guidelines
Reply #1 - Jul 23rd, 2008, 11:39pm
The sheet resistance of poly is fixed and so is the max. current density. If you are trying to realize  a particular value of resistance at a certain current density, then you only have the choice of varying W. L is automatically determined.
Vivek
eppramod
Reply #2 - Jul 24th, 2008, 10:52pm
Hi Vivek,
I understand that point the rho or Jmax values are fixed in a particular technology for poly resistors and you may fix mostly W(or L?) and Come up with a L (or W)for realising particular resistance.
But this fixing W (or L?) minimum value can be (will be) determined by Jmax limits.But what i came across was this minimum W or L is now determined by Power density more than Current density.
I wanted to know if this is true.
Thanks for your response
Pramod
vivkr
Reply #3 - Jul 24th, 2008, 10:55pm
Hi Pramod,
They are the same thing. Since sheet resistivity is a process constant, a fixed power density corresponds to a fixed current density.
Vivek
wave
Reply #4 - Dec 29th, 2008, 8:41pm
I've actually found that for small Poly R's with high currents (several mA), I need to watch the # of contacts the layout tool puts on the end.
A default of 2 contacts may be a large % of effective resistance AND not meet current density guidelines.
~WAVE Cool
Maks
San Jose
Reply #5 - Jan 23rd, 2009, 12:32pm
wave wrote on Dec 29th, 2008, 8:41pm:
~WAVE Cool
You may have to watch not only the number of the contacts, but their layout as well - the edge and especially corner contacts/vias in the contact/via array may carry much higher current than the average current...
  Maks
