Jul 17th, 2024, 4:37am
to solve differential equations in verilog-a? (Read 3466 times)
msdryxon
Jul 26th, 2008, 12:25am
  Now I'm using verilog-a to do some research on modeling kinematic structures. We all know that ddt or idt is accepted in verilog-a, such like the following sentences:
  Pos(v)<+ddt(x);
 But if Fdrv is from a source outside my module and i want to output the x in the following differential equation, how can i?
 a*x''+b*x'+cx=Fdrv
  i've written these codes,
  .......(includings)
  module test(Fdrv,x);
      inout Fdrv,x;
      kinematic Fdrv,x;
      kinematic v; //temp. var. to hold ddt(x)
      parameter real a=xxx, b=xxx, c=xxx; // assume a,b,c are properly defined
              analog begin
                   Pos(v)<+ddt(x);
                   F(Fdrv)<+a*ddt(Pos(v))
                                 +b*Pos(v)
                                 +c*Pos(x);
   if i input x to module test, i will get proper output of Fdrv, but if i want to input Fdrv and get the
proper value of x, which means i want to solve this differential equation, it never works.
   How can i solve this problem? thank you very very much....
Re: to solve differential equations in verilog-a?
Reply #1 - Jul 26th, 2008, 10:10am
You can use indirect branch assignment. Looks something like this ...
kinematic drv, x;
kinematic_v v;
analog begin
   Vel(v) <+ ddt(Pos(x));
   Pos(x) : a*ddt(Vel(v) + b*Vel(v) + c*Pos(x) == F(drv);
The indirect branch assignment can be read: "Find Pos(x) such that ...".
Here I am assuming that I separate discipline dedicated to velocity. Otherwise the tolerances get out of whack.
