May 17th, 2024, 11:05pm
difference between phase noise testing and simulation (Read 4699 times)
xuel
Aug 04th, 2008, 7:33pm
In simulation the phasenoise is very good, is 100dbc at 1MHz.
But in testing, phasenoise is only 60dbc at 1MHz.
But the jitter is not large, 20ps peak-to-peak measured from oscilloscope.
Why is the measured phasenoise so bad?
luantan
Re: difference between phase noise testing and simulation
Reply #1 - Aug 10th, 2008, 8:37am
anybody knows? Smiley
begin to do
ACWWong
Oxford, UK
Reply #2 - Aug 11th, 2008, 12:30am
I'm assuming your simulation gives -100dBc/Hz
In such a case your measurement shows about -95dBc/Hz at 1MHz offset.
That is -60dBc in a 3kHz RBW, so you need to adjust the marker by 10*logRBW=34.8 dB.
Often the analyser has the marker on noise function which will take into account the RBW automatically (and more accurately).
So in fact you are 5 to 6 dB of where you expect to be. The reasons for this can be many e.g. discrepenacy in models, simulation setup issues, measurement issues, PCB design, noise pickup etc.....
iaman
China,Shanghai
Reply #3 - Sep 12th, 2008, 8:32am
ACWWong wrote on Aug 11th, 2008, 12:30am:
Great.
from the test picture, we can find some details:
1. RBW is 3kHz, so we should  normilized the PN to dBm/Hz.
2. the  Spectrum analiyzer power dector is peak dector , you should change the power dector to rms dector.
2.
Simulate~~~~~~~~~~~~~~
View Profile iaman   IP Logged
RFsage
Melbourne, Australia
Reply #4 - Sep 15th, 2008, 12:53am
The phase noise at higher offset frequencies is generally limited to thermal or white noise floor of your load. If you are using a resistive load you should expect higher noise floor.
