Jul 4th, 2024, 10:46pm
ft=GBW? (Read 5437 times)
rf_man
ft=GBW?
Aug 07th, 2008, 12:40am
Is it completely correct that the GBW of an amplifier is equal to the ft
of the used technology?
Re: ft=GBW?
Reply #1 - Aug 7th, 2008, 12:55am
rf_man wrote on Aug 7th, 2008, 12:40am:
No, it's completely wrong.
If you mean amplifier which is composed of single transistor and has no parasitic effect regarding bias, etc., GBW will be same as ft.
buddypoor
Bremen, Germany
Re: ft=GBW?
Reply #2 - Aug 12th, 2008, 12:38am
Normally, the term GBW is used only in case of integrated amplifiers (opamps). In this case, GBW is identical to the transit freqency only if the opamp is universal compensated (only one dominant pole in the amplifiying region).
If there is a second pole within this region, the GBW product is larger than Ft.
Re: ft=GBW?
Reply #3 - Aug 13th, 2008, 5:43pm
buddypoor wrote on Aug 12th, 2008, 12:38am:
Starter of this thread mentions "ft of the used technology" not transition frequency of amplifier like following.
Is it completely correct that the GBW of an amplifier is equal to the ft of the used technology?
buddypoor
Bremen, Germany
Re: ft=GBW?
Reply #4 - Aug 14th, 2008, 1:11am
Quote: Starter of this thread mentions "ft of the used technology" not transition frequency of amplifier like following.
Hi, pancho_hideboo
If ft is NOT identical to the transit frequency - what is it ?
Please explain to me. Thank you.
Re: ft=GBW?
Reply #5 - Aug 14th, 2008, 1:19am
buddypoor wrote on Aug 14th, 2008, 1:11am:
When we refer to "ft of the used technology", it is a transition frequency of H21 of transistor at some bias condition(e.g. Vds=1.5V, Ids=1mA).
This is NOT identical to the transition frequency of amplifier.
buddypoor
Bremen, Germany
Re: ft=GBW?
Reply #6 - Aug 14th, 2008, 4:13am
pancho_hideboo, thank you.
I was a bit confused as a phrase "ft of technology" is "uncommon" for my opinion..
However, if the transit frequency of the current gain for a transistor was ment, the original question sounds a bit "strange" to me, because it is logical that the GBW of an amplifier (containing some transistors, perhaps of different types) never can equal the transit frequency of one of the transistors.
Thanks and regards
