Dec 15th, 2025, 11:53pm
ADS simulator error (Read 6857 times)
Turin
Greece
ADS simulator error
Aug 15th, 2008, 6:22am
I have an error in the simulation in ads 2004 and i wonder if anyone know how the correct it.The simulator can't start because it can't identify a the desing kit 's components.
The exact ,message is
Error detected by HPEESOFSIM during netlist parsing.
   `MP1' is an instance of an undefined model `pmos'.
Status / Summary
HPEESOFSIM (*) 2004A.501 Oct 12 2004 (built: 10/12/04 22:26:01)
Copyright Agilent Technologies, 1989-2004.
Simulation terminated due to error.
I'm quite sure the desing kit is installed correctly..Any suggestions.....?
Re: ADS simulator error
Reply #1 - Aug 15th, 2008, 10:06pm
Turin wrote on Aug 15th, 2008, 6:22am:
Show me a status report of installed design kit.
Even if you can see components in pallete and place them in schematic, it is very possible that design kit is not installed correctly.
Possibilties are:
(1) Design Kit is not installed correctly.
    Site Level or User Level ?
(2) Installed Design Kit is not valid for ADS2004A(this is faily old).
(3) Content of Design Kit is broken or incomplete due to some reason.
Turin
Greece
Reply #2 - Aug 16th, 2008, 3:31am
User level....The kit is specified in the documentation as ads 2004 or higher so it should be ok....
nano_RF
madison
Reply #3 - Aug 20th, 2008, 8:29am
I think you might not have placed the process model information block in your test bench. From the component scroll down button, select your process kit and there should be a process info block. Place it on to your test bench.
