Jul 17th, 2024, 11:34pm
Randomization for PWM DcDc-Converter (Read 5611 times)
Berti
Aug 25th, 2008, 5:06am
I would like to reduce EMI of an existing PWM DcDc-Converter.
Therefore I added randomization, which improved EMI. However, the randomization
signal appears at the converter output (see figure).
Does anybody has suggestions how to improve that?
Thank & Regards
NiceFeng
Re: Randomization for PWM DcDc-Converter
Reply #1 - Apr 12th, 2009, 5:16am
Hi, Berti,
 How did you modulate the duty cycle?
 I think your output waveform is related to the period of your modulation signal. It seems it is too fast.
Feng
Berti
Reply #2 - Apr 14th, 2009, 11:27pm
Hi Feng,
The period of the modulation signal is given by the length of the LFSR which is 8bit in my case.
However, in the meantime I found several publications which confirm the presence of low frequency noise if randomization is applied. And since the DcDc-Converter output is finally regulated by an additional LDO this is not really a problem. Especially since the PSRR of the LDO is very good at low frequencies.
Thank you. Cheers.
krab
Reply #3 - Jul 8th, 2009, 1:30am
Hi Berti,
I have just started a DC-DC IC design where +-3% variation in the switching frequency is needed for spread spectrum control.
I considered using a 8 bit LFSR just like you but I am wondering if the period of the register (8 cycles) is too short. I plan to use the current clock edge to drive the LFSR and the new state of the LFSR will determine the next cycle frequency.
I am curious, after your research what is the reason why you have low frequency noise on the output?
I am also considering maybe using a low frequency sawtooth to modulate the duty cycle, but I am not sure how I should choose the freq of my sawtooth. Any suggestions?
Also any references on how one might implement this sawtooth modulation on chip will be much appreciated.
Cheers
Berti
Reply #4 - Jul 9th, 2009, 12:14am
I came to the conclusion that the low frequency noise is inherent to randomization. I found several publications which report on that. Basically it makes sense: If you add dither to a system, the dither will typically also appear at the output.
However, since the DcDc-Output is further regulated by an additional LDO in my case, low frequency noise will be suppressed by the LDO.
The choice of the switching frequency is related to your system (spectral interference planing). Often a low frequency is preferred, which however translated into a large inductor.
Cheers
