Aug 18th, 2024, 3:14am
IM3 problem in the active low pass filter (Read 4640 times)
James Bond
Sep 02nd, 2008, 12:24pm
Hi, guys
Does anybody know how to reduce IM3 in a nth order active low pass filter? I guess one has to start from the designing a low IM3 opamp, right ? The only way I am realizing is to increase the signal swing, can you suggest any tips ?
BR
James
buddypoor
Bremen, Germany
Re: IM3 problem in the active low pass filter
Reply #1 - Sep 3rd, 2008, 1:24am
James Bond wrote on Sep 2nd, 2008, 12:24pm:
Increase ???
For my opinion, the linearity of a filter circuit depends strongly on the chosen topology.
Therefore the question: What is the structure of your filter - cascade or compact/direct realization ? Which topology ? What kind of amplifier - opamp or OTA ?
James Bond
Reply #2 - Sep 3rd, 2008, 7:55am
Forgive me I didn't explain my situation clearly. The situation is that the topology(leapfrog) is fixed , filter order is fixed, schematic is fixed. The only thing I can do is to optimize opamp I think . As I mentioned above, try to give more headroom so that it can handel larger input signal.
BR
James
buddypoor
Bremen, Germany
Reply #3 - Sep 3rd, 2008, 8:22am
Yes, if everything is fixed - except the opamp type - then, indeed, the opamp seems to be the only part to be "optimized" - whatever this means. May I remember you, that - in addition to more or less classical sources of non-linearity - sometimes slew induced distortions exist.
That means, you could try to use opamps with a higher slew rate.
I suppose, you have already checked the different signal levels the various opamps have to accept (saturation effects).
Thatīs all I can say at the moment.
Good luck.
cgt
Stockholm
Reply #4 - Apr 3rd, 2009, 6:15am
One common problem is that the OP amps output stages are running out of current. This will set the compression point and hence the linearity to some degree depending on loop gain.
In RFIC RX designs this normally happens for large interferers in the first stages of the filter. For the wanted channel this happens for the last stages. I assume that there is (distributed) gain in the filter.
Please remember that the out of channel interferers do "see" a quite low impedance wich requires higher current than the wanted channel (in the first stages).
/CG
aaron_do
Reply #5 - Apr 3rd, 2009, 6:31pm
I guess i must be missing something...can't you just increase the loop gain of the op-amps?
cheers,
Aaron
EDIT...just noticed how old the original post is...
Reply #6 - Apr 5th, 2009, 4:56pm
Two things needed:
1. Examination of the worst case (largest) signal amplitudes at the outputs of all active amplifiers. Need to stay well within the limitations of the amplifier going into compression. FWIW an OTA will give wier amplitude swings (AB output type OTA)
2. Get the open loop gain of the amplifiers as high as possible and maintain the gain out to a BW that is a decade (or more) beyond you passband.
