nobody
Hello, Sheldon
Thanks for your help. Like you said, adding another SC stage is helpful to reduce the charge injection which goes out to the output terminal of the 1st SC. I should tell my problem specifically. I care about the effect of charge injection at the input or so-called residual offset. When simulating a preamp with an ideal clock(Gswitch in HSPICE)for auto zeroing, there is no charge injection. However, replace an ideal clock with real mos switches, an error is found out. Regards,
nobody
