Oct 28th, 2024, 3:56pm
bandgap trim and cap-less LDO issue (Read 435 times)
trashbox
Sep 07th, 2008, 10:26pm
1.how to realize the trim in bandgap? What's the difference between trim and options by logic control?
2.If LDO's dominant pole is at error amplifier's output and the phase margin is ok without large off-chip capacitor. Is it so-called cap-less LDO? In my design, use one-stage foled-cascode(get large output impedance at error ampifier out) and large pmos pass element (spec requires large output current) so that the pole at error amplifier is the dominant pole. Is it ok?
Thanks!
Tlaloc
Dallas, TX
Re: bandgap trim and cap-less LDO issue
Reply #1 - Sep 9th, 2008, 8:04pm
As far as the bandgap trim is concerned, the most common way that I have seen is to trim one of the resistors setting up the del-Vbe term in the equations.  Of course, how accurate you need it is another question.  If you trim with switches with binary weighted resistors, you can run the risk of the switch resistance interfering.  If you can directly laser trim the resistors, you can get good results, but generally you can suffer from package shift.
The only other way that I can think of with a voltage output is to change the transistor ratios, but this would be a very coarse trim.  If you had a current output, you could also change the current mirror ratios.  Again, that would most likely be pretty coarse.
I did not understand what you second question in #1 meant.
trashbox
Reply #2 - Sep 10th, 2008, 12:31am
Hi Tlaloc,
Thanks for your comments. The second question in #1 means:
If I use logic signal to control the resistor, means 2b'00 is 0.9*R, 2b'01 is R, 2b'11 is 1.1*R and 2b'11 is 1.2R to get a target bandgap output.
Another question is, can trim techniques tune bandgap output even when there is process variation between different wafer? Suppose in mass production, bandgap from different wafer hasn't good output such as 1.1v, 1.2v, 1.3v, 1.2v etc. Can trim techniques tune all bandgap back to 1.2v around. How to realize it?
Thanks!
Tlaloc wrote on Sep 9th, 2008, 8:04pm:
Tlaloc
Dallas, TX
Reply #3 - Sep 10th, 2008, 8:27pm
That is a type of trim, so I am still unclear what your question is.
None of the bandgaps that I have ever worked on ever had anywhere near that variation.  If it did, it was broken.
In short, yes.  Otherwise we wouldn't bandgap circuits in the first place since they wouldn't be manufacturable.
Quote:
How to realize it?
If my previous post didn't answer your question, what exactly would you like answered?
hzfeiyun
Reply #4 - Sep 10th, 2008, 11:55pm
Is it possible for a general cmos process if they do not monitor VBE in wafer?
I guess you may need a auto-trimming method ?
trashbox
Reply #5 - Sep 12th, 2008, 2:37am
This type of trim is ok in lab test and I can set register by hand. However if mass chips are tested on ATE and the bandgap output need to be trimmed by this type. How does the equipment trim it automatically?
I ever saw there are some extra pads in bandgap for trim. Can ATE trim the resistor in bandgap by these pads automatically? How does ATE works?
Thanks!
Tlaloc
Dallas, TX
Reply #6 - Sep 12th, 2008, 9:40am
You typically have some sort of OTP (one-time programmable) structure.  These can be fuses, floating pmos, Non-Volatile Memory (Flash or EEPROM), etc.  During test, the tester can determine the code, and then burns that code into the OTP.  Then every time the part turns on, it reads it's own unique trim code back out of the OTP.
trashbox
Reply #7 - Sep 16th, 2008, 1:17am
Hi Tlaloc!
Thanks for your reference. It seems OTP has higher test cost. Right?
Trashbox
Tlaloc wrote on Sep 12th, 2008, 9:40am:
Tlaloc
Dallas, TX
Reply #8 - Sep 16th, 2008, 7:53am
It depends on the structure used.  Fuses can have higher costs since they need a laser, but that is not generally true.  Some of those mentioned can also be burned (written to) after packaging, so one could account for package stress as well.  In some cases, depending on the flavor of OTP, they are not any more expensive.  That is, they can be processed using a standard process, and they can be burned without special equipment.
HdrChopper
Reply #9 - Sep 18th, 2008, 7:01pm
Tlaloc wrote on Sep 16th, 2008, 7:53am:
A typical example of these are polysilicon or just metal fuses. They are built out of regular components from standard process.
Tosei
Keep it simple
msudans
India
Reply #10 - Nov 20th, 2008, 10:56pm
Hi trashbox,
   Regarding your Question2:
  If your LDO does not have an external decap, it is a cap-less LDO.
However, you may still need some  internal decap to supply high frequency current spikes (typically 100-200pF).
 Once you add this internal decap, you will find that your uncompensated LDO phase margin is degraded and you will need miller compensation.
-m
