Sep 26th, 2026, 1:40pm
limiting amplifier options (Read 2820 times)
aaron_do
Nov 21st, 2008, 12:29am
I want to design a limiting amplifier using nmos differential pair and nmos diode connected loads. Unfortunately due to the body effect, the sizing ratio between the loads and the differential pair has to be pretty huge even for moderate values of gain.
So i've come up with 2 simple solutions (there are other more complicated ones).
1) Use deep n-well transistors with source-body connection. Unfortunately I guess the matching will take a hit because of the increased device separation.
2) Use VNPN transistors. VNPN transistors are larger, but get better matching. I'm also not so sure how well modeled they are.
So does anybody have an opinion on which one would be preferable, or maybe even a better solution?
thanks,
Aaron
ACWWong
Oxford, UK
Re: limiting amplifier options
Reply #1 - Nov 21st, 2008, 4:50am
aaron_do wrote on Nov 21st, 2008, 12:29am:
you could try nmos bulk to vdd.... this will help in terms of lowering threshold and compacting layout... (the only caveat i see are latchup implications)
Paul
Switzerland
Reply #2 - Nov 22nd, 2008, 1:06pm
Hi Aaron,
Could you explain why you don't want to use PMOS loads (parasitics?)? The drawback I see with (1) is that the RWell (i.e. the local P-well) will be connected to the output node, right? This will increase the parasitics on the output and lower the BW of the limiting amp. In case (2), you will have an important penalty in area due to the bipolar device sizes.
Paul
