Sep 28th, 2024, 4:14am
error source in bandgap (Read 6018 times)
trashbox
Sep 07th, 2008, 11:47pm
There is many error sources in bandgap such as op offset, passive device mismatch, current mirror mismatch etc. Is there any papers who compare these errors, figure out which is the most important?
If chopper amp is used in bandgap, which chopper amp has the smallest area? I read Burt's paper on JSSC 2006, its area is 0.8m^2 under 0.6um. It is too large for bandgap reference.
Thanks!
HdrChopper
Re: error source in bandgap
Reply #1 - Sep 8th, 2008, 6:25pm
Hi Trashbox,
Be careful!...if you are going to chop the BG reference be aware the amplifier is not the only and (eventually) not the main source of offset in the circuit.
If you get offset in the bipolars used for building up the delta VBE that will generate a lot of offset (the offset current you'll get will be proportional to the e^Voff. Therefore you might want to think about chopping the bipolar translinear loop too.
Tosei
Keep it simple
trashbox
Reply #2 - Sep 8th, 2008, 7:21pm
Hi Tosei,
Thanks for your remind! Yes, the current mirror should be chopped,too. Is there any other issues which should be careful?
I ever saw a paper from Philips Research Laboratories, tile is : A bandgap reference using chopping for reduction of 1/f noise and random offset. Did you ever read it? I can not download.  :(
HdrChopper wrote on Sep 8th, 2008, 6:25pm:
Hi Trashbox,
Tosei
hzfeiyun
Reply #3 - Sep 11th, 2008, 12:12am
trashbox wrote on Sep 7th, 2008, 11:47pm:
Thanks!
Statistical Analysis and Optimization of a Bandgap Reference for VLSI Applications
J ¨ URGEN OEHM1 AND ULRICH GR ¨ UNEBAUM2
1Infineon AG, D¨usseldorf, Germany
2ZKOM GmbH, Dortmund, Germany
E-mail: J.Oehm@infineon.com; Grueneba@zkom.de
Received February 15, 2001; Revised February 27, 2001; Accepted February 27, 2001
Abstract. Voltage and current references are widely needed for all kinds of integrated circuits, as most applications
require temperature-independent references with a high reproducibility in mass production. For this purpose
normally bandgap references are used. Though it is a common task to set up an application specific bandgap circuit,
handling of the statistical design aspects is often not a standardized step in the design flow. This article describes
some of the steps that were taken during the design of a bandgap reference for a given VLSI application. All
statistical simulations were carried out with the simulation tool GAME (General Analysis of Mismatch Effects)
which is used at Infineon/D¨usseldorf since 1999.
Key Words: bandgap, statistical analysis, mismatch, optimization, simulation
weber8722
Reply #4 - Mar 17th, 2009, 7:17am
which impacts are most critical on BG accuracy depends on circuit topology (some have no op-amp at all) and sizing of Rs and transistors.
If you do a Monte-carlo mismatch simulation in Cadence ADEGXL, you can get a full sensistivity report showing you which factors are most important (like Vth-mismatch of M2). Also Spectre dcmatch analysis is perfect for this (but not for chopper-BG's).
Bye Stephan
RobG
Bozeman, MT
Reply #5 - Jul 29th, 2009, 6:19am
Thanks!
This is probably too late to help you, but maybe someone else... The importance depends on your process variations and the design topology you use. Generally you want to make the ΔVBE as large as possible. This reduces the ratio of the gain resistance which lowers the sensitivity to everything (and also lowers the noise). Not much you can do beyond that for topology except chopping.
Once you decide on a topology there is a method to optimize the areas allocated to each device. I did a paper that might help you optimize (CICC 2004): http://web.engr.oregonstate.edu/~gregoire/papers/CICC2004.pdf . The resulting bandgap had a σ of 2mV. The paper also presents a substrate PNP Darlington topology that doubles the ΔVBE.
One thing you should do is make the area of the gain resistors equal by using a parallel/series structure. For example, for a 9:1 ratio you would use 3 Rs in series for the big resistor and 3 Rs in parallel for the small resistor. This method reduces the area considerably because resistor mismatch of this gain circuit is generally the highest mismatch contributor.
rg
RobG
Bozeman, MT
Reply #6 - Jul 29th, 2009, 6:25am
Hi Trashbox,
Tosei
In terms of actual mismatch, the substrate PNPs in the CMOS processes I have used has always been negligible (for areas > 10um^2 anyway). It is determined by emitter area (P+ implant) which is very precisely controlled. You DO need to common centroid the bipolar structures used to generate the ΔVBE or the circuit will be sensitive the effects of changing plastic package stress and gradients (thermal, etc.).
rg
subgold
Reply #7 - Sep 7th, 2009, 1:06am
Hi Trashbox,
Tosei
sorry to dig up an old post, because i happened to have a wondering on the same topic.
as Tosei pointed out, sometimes the main error source is not from the opamp. but in such cases, how are we supposed to chop, for example, the bipolar loop? it is not a fully differential loop, which is the basic requirement to apply a chopping scheme.
