Sep 28th, 2024, 2:21am
what is meant by bleed current for an LDO regulator? (Read 3759 times)
yvkrishna
Jul 23rd, 2009, 8:28am
thanks
vamshi
HdrChopper
Re: what is meant by bleed current for an LDO regulator?
Reply #1 - Jul 24th, 2009, 8:41pm
I guess a min current consumption provided by a bleeding resistor beyond the actual load that has to supply the voltage for....if the load is purely capacitive then you need a min load current in order to bias the regulator...
Tosei
Keep it simple
NeoLearner
Reply #2 - Sep 3rd, 2009, 4:01am
It's most likely a current that flows through the differential input pair but is not mirror to the second stage.
So it's like having a current source in parallel with your current mirror.
Because of the increased current, the input pairs have a bigger gm. Thus, the complete opamp has higher gain.
Because the current is not mirrored, it does not cause an increase in current consumption of the second stage.
Reply #3 - Sep 5th, 2009, 11:56am
It is the minimum current going out thru the pass transistor with external current load set to zero, while still maintaining a stable system.
This can be internally set (thru a load) or externally required (it varies with the design)
Not to be confused with the ground pin current - wich is all the current to run the internal LDO circuits (bandgap and feeddback control system typically)
Mind you, I dont think there is an ISO or IEEE standard definition here so a vendor may define this a little differently.
yvkrishna
Reply #4 - Sep 7th, 2009, 1:16am
Thanks  for the replies.
