Sep 28th, 2024, 2:46pm
how to avoid extracting RFMOS in Calibre PEX? (Read 7521 times)
jlee
Sep 10th, 2008, 2:28am
To avoid extracting RFMOS parasitics in Calibre PEX, I used hcell file and gate level extraction type.
Here is my hcell file:
rfnmos1v nmosrf
After extraction, I found following warnings.
1) Warning: Hcell rfnmos1v not located or not allowed.
2) Warning: Name "rfnmos1v" in hcell correspondence file not found in layout - ignored".
In RVE, net parasitics shows that parasitics has still be extracted.
I don't know how to solve this problem. Could you please give me some suggestions?
Thanks in advance!
Jason
Re: how to avoid extracting RFMOS in Calibre PEX?
Reply #1 - Sep 11th, 2008, 3:03am
Hi Jason,
It seems that the Calibre xRC had not find the cell named rfnmos1v.
Yawei
jlee
Reply #2 - Sep 13th, 2008, 12:13am
Thanks for your input.
What ahout my hcell file? Is it right?
Which one should follow the name in layout, the former or the latter?
Reply #3 - Sep 23rd, 2008, 1:18am
I think the former should follow the layout view name, and the latter for schematic view.  -- Yawei
Reply #4 - Oct 30th, 2008, 2:28am
Hi Jason,
In the hcell file from a Big foundry, the first column contains the sub-circuit name for the RF devices; the second column contains the LVS model name defined in the LVS command file. I extracted a small layout with this file successfully.
I looked at the Calibre manual for 2004 and 2007. It states that the first column is layout name and the second column is source name. I don't know which one is correct now. Maybe both are correct.
Yawei
« Last Edit: Oct 31st, 2008, 2:22am by ywguo »
