Jul 20th, 2024, 9:27am
strange results for phase response (Read 2185 times)
dimita
Israel
Sep 11th, 2008, 12:44am
I run AC simulation of some opamp in unity gain buffer configuration(open loop response), the open loop gain seems to be usual response with dominant pole at low frequencies, but the phase starts from -180 degree and rising. There is no invertion at DC, can anyone explain such phase behaviour?
regards,
Dmitry
dimita
Israel
Re: strange results for phase response
Reply #1 - Sep 11th, 2008, 12:46am
For some reason I can not upload the attachment with waveform Sad
regards,
Dmitry
tempora123
Reply #2 - Sep 16th, 2008, 4:48am
Maybe your setup is wrong. Try this;
- connect Vdc (reference) to in_positive
- connect vsin acmag=1 to in_negative (feedback loop branch)
- run dc with closed loop
- run ac with opened loop
You should get a good results then.
L.S.
