Jul 20th, 2024, 12:31pm
Using verilogin (Read 4604 times)
dinac
Belgium
Using verilogin
Sep 17th, 2008, 2:06pm
I am trying to do a co-simulation of my control logic for my ADC.
I want to verify my Flow. i am new to mix simulation.
I wrote a vhdl code for my control-logic and got a gate-level verilog.Netlist of my design, using standard-cell '.lib' or '.db' format.
And now i am trying to parse this Netlist through ' verilogin '. and would be simulation with the other analog parts of my ADC.
The 'Reference Library' in verilogin? is this the same standard-cell '.db'\'.lib' file? because when i tried to define this in cds.lib, i find no cells in the ' Library Manager '. is this Ok?
Even though I discard this and try parsing the Netlist. i get some errors:
VerilogIn: *W,31 => Module X in FSM_file  not defined.Module FSM_file will be imported as functional.
VerilogIn: *W,101 => Could not find symbol master for instance
XY .Functional view won't have this instance.
Please Help me ..
Thanks........
bernd
Munich/Germany
Re: Using verilogin
Reply #1 - Sep 18th, 2008, 1:35am
NO this is not OK, you need a Cadence DFII library of your standard cells for importing your Verilog Gate Level, this is a different library format as *.db or *.lib.
You usually get the Cadence DFII library form your standard cell vendor or you have to create the Cadence DFII library, cell views and
netlist properties, yourself. No that trivial for a beginner.
* bernd
Just another lonesome cad guy
dinac
Belgium
Re: Using verilogin
Reply #2 - Sep 18th, 2008, 6:32am
Hi  bernd / all,
Thanks for your reply.
I guess i solved it
1. Reference Library "CDK"
2. -V option i provided the link of the standard-cell file in verilog format. ".V"
I found few errors, mentioning the verilog
" Verilog definition for module AND2 was not found. Using lib 'techlib' cell 'AND2' view 'symbol' as its symbol.
But i guess I could discard this.
Thanks a lot Again
cheers
dinac
