didac
![* *](https://designers-guide.org/forum/Templates/Forum/default/stargold.gif) ![* *](https://designers-guide.org/forum/Templates/Forum/default/stargold.gif) ![* *](https://designers-guide.org/forum/Templates/Forum/default/stargold.gif)
![](https://designers-guide.org/forum/avatars/blank.gif)
There's a million ways to see the things in life
manresa,spain
Hi, If I understand correctly you are upconverting low power levels to mimic the channel losses, is it right?, Why don't you upconvert a higher power level to avoid the problems of LO leakage and then you put a resistive attenuator fixed or variable after the mixer to mimic the losses?, it's the only solution that I can think about that doesn't imply a change of the mixer. Hope it helps,
